phillnjack2
Ensign
- Joined
- Apr 30, 2011
- 918
Ok i have one of these bright red prop Guards it came with the engine when i bought it.
it needed a couple of repairs and they have been taken care of.
Now the promotion of these things leaves you thinking "it cant realy be that good" or can it ?
The makers claim for these to improve handling, !!! well yes i can see that by having the propeller in a
shrouded housing can improve the steering due to the thrust being kept more in one place rather than spinning
off the prop and spreading the prop thrust out instead of backwards .
But a gain in speed ? surely this one is a bit hard to take on board ?
Better fuel consumption, as the boat is quicker to plane and stays on plane at lower speeds ???????
The trim of the boat again they say " is better" with the "PROP GUARD"..
Now this will be the first time ive used one of these on any outboard, i have used hydrofoils and had good results.
Also used the adder rudder and had good results with them on smaller outboards.
Has anyone here had or have a prop guard fitted and what do they think of them ?
any of the good bits or bad bits please, as i dont want to be wasting my time and effort fitting the guard only
to want to fill in the drilled holes on the skeg straight after i try it out.
I will be using this 60hp triple evinrude on a 13ft orkney dory, very similar to a classic 13 boston whaler at
first glance.
At the moment this boat has a tremendous holeshot and is ok on the handling, but nothing special.
I dont mind losing a touch of speed, but dont want drastic reductions or massive fuel consumption differences.
The reason i want to fit the guard is
1st for people protection and
2nd for prop protection..
here is a pic of the guard loosely fitted on my engine.
I just think it would be a safer outfit if the guard was fitted !!!!!!!!!!!!!!!!!
phill......
first glance.
phill......
