prop guide
mike12
Hi! Just got the Hub off the prop shaft on my 1973 merc.7.5 hp. Behind the hub and butting up to the Bearing Carrier is what mercury calls a propeller guide or collar. Was this suppose to come off with the prop and do I need to replace it? I need to replace the Bearing Carrier seal,what is best way to take off propeller guide? Thanks for Your Help!!!
moderator1
Re: prop guide
I believe you mean the thrust washer....It might take a small puller to bust it free, or protect the outer edges of the gearcase and use 3 screwdrivers...
mike12
Re: prop guide
Thanks for reply moderator1! and you may be right but Mercury has it listed as Part# 86665A1 and calls it a collar or propeller guide.Looks like it fits against back of prop? Any Help Appreciated! Thanks, Mike
mike12
Re: prop guide
You were right moderator1 I went to BAM web sight and put in part#86665A1 and it pulled up as a Thrust Washer. Thanks again for your help now i have to find a puller that will work. Mike
mike12
Re: prop guide
Thanks Kenny that did the trick!!! Got every thing cleaned up and waiting for my prop to be rehubed. I would like to replace the front seal and roller bearing in the bearing carrier can this be done without pulling the prop shaft? Thanks again!!! Mike
