underpressure
- Joined
- Mar 22, 2009
- 28
this is my first boat ,searched the forums could not find an answer,so here we go i have a 1974 14 foot starcraft boat approx weight is 180lbs ,the motor is a 1975 johnson model 15r75c ,the prop that is on the motor is pretty beat up,took boat out for a trial run and it works but seems to have a vibration at wot and boat dont seem to be moving very fast ,i weigh about 225lbs ,the pin is not sheared,the numbers on the prop are 9.5 by 10 ,we want to get a new prop that will push the boat a little better ,i was at 4800rpms roughly with a tach (digital) motor runs strong just dont know if im expecting to much from the motor or if there is a better prop that i can get to move the boat a little faster,thanks again in advance for any help about prop pitch and diameter
