bsutravis
- Joined
- Jun 11, 2010
- 64
I've inherited this boat from my late Grandpa and I am in the process of fixing many things that have been neglected. One thing I notice while running is every now and then the prop seems to "slip" in the water and the RPM's will rev and you have to back off the throttle so the prop "grabs" the water again. Usually this happens in rough water or while turning a tight turn at high speeds.
I'm looking at replacing the prop so that is my question: What do you guys recommend? I know that's a loaded question so here's some background info:
'77 Mercury 1150 - 115 HP
Boat is an '88 16' - Fabuglass Fish n Ski
Prop Numbers: 48-32746A3 21P and is Aluminum
The boat is rated for 6 persons or 800lbs, 1350lbs total including persons, gear, and motor. The majority of use is running with a 2-3 persons weighing less than 450, occasionally putting the kids on a tub or skis but 90% of the time it's just taking me and my son from one fishing hole to the other. Currently I'm not sure what the top speed is but I can take my GPS and get an accurate reading on that. I'm just worried that the 21P is the reason for the RPM surge and perhaps I should go to a different pitch.
Thoughts???
Thanks!
Thoughts???
Thanks!
