Need some help from the experts here at iboats. I own a 2004 17ft Century center console. The boat with about 15 gallons of gas,hull and motor is 3,350 lbs. this weight is without passengers which are usually 2 and gear. I use it for fishing only. Top speed is not a concern. The prop from the factory is an 18 1/4 X 17k. At WOT my 2004 90 TLRC Yahama will only turn 5000 rpm. I would like to get closer to 5500 RPM. Either stainless or aluminum, I have no preferance. I would like to know if it is a thru hub exhaust or not and how can you tell?
