Prop Help
Gerry_Finney
I am trying to prop my boat and I need a little help. There is not much to go on here because what is going on, so I am taking good guesses at this point. I have a 21.5 foot bayliner ciera with a cuddy cabin. The old engine was a volvo 125 with a 270 outdrive and 14X 17 prop. I replaced the engine with a merc 260, and geared the outdrive to a 1.6 ratio. With my current (17) pitch, I got to about 25 miles an hour at 4000 RPM and could have pushed it a lot more but in an effort to save my engine I couldn't get WOT. According to http://www.a1discountprop.com/volvo-michigan.htm <br />I need a 14X23 which isn't made or available anymore. The only thing they use is boat length and HP to calculate it though. If anyone has any good guesses or running something similar, please respond<br />-Gerry
rolmops
Re: Prop Help
You should hit "Propit right"on the afore mentioned website and you will get more help and info than you need.
roy w. shakun
Re: Prop Help
The place for props is Ace Propellers. their prices are great and if they don't have it, they will find a match, they carry solas, as well as power tech. you'll be glad you called.<br /><br />1.800.567.7767<br /><br />They taught me more about props in one phone call than,,,,,,,,,,,,,!
