I am running a 1993 Alumacraft Dominator with a 1993 55HP EVINRUDE(tiller).Motor is mounted with CMC power tilt bracket.Cavitation plate is roughly 1 inch above transom bottom.Prop is Michigan stainless measuring 13 3/4 by 15.(standard).Fully gased and loaded,including Merc9.9 kicker my GPS speed is a solid 30mph,with tach reading of 5200 rpm.Hole shot is not real solid,,,some slippage is happening.I have drilled holes behind the prop blades to help improve this but went to big on the size,,plumber puttied them back up.I would like recommendations on how I can improve top end and hole shot.I think I can get more RPM out of her,but am not sure how to proceed.Also because the engine is mounted on the CMC bracket,can I raise her up a bit more.
