Prop Hub Replacement
xcelr8z28
i just ordered a prop online, and it has a 15 spline hub in it, and it was off a OMC outdrive the year or model is unknown, my questions is I have a 1993 Alpha I sterndrive, and according to the companies webpage which is Stiletto that prop is supposed to work with it. Obviously it has the wrong hub and i was wondering if anybody knows the procedure for replacing the hub. Thanks for you help again!
Re: Prop Hub Replacement
Ayuh,... Late model OMC used the same spline count as Merc....
If it's a Pressed Hub prop,...
The hub needs to be pressed out,+ a replacement pressed in..
Any Prop Shop can handle it...
