1996 Thompson, 7.4 Mercruiser Bravo One, with mirage prop. Last summer with boat loaded and running mid throttle, boat came down off plane and engine revved. I reduced to idle and tried to re-plane but it free revved again. Idled home and parked it. Ever since that episode, it has planed normally (but never had more than two in the boat). I put sharpie marks on the shaft nut and prop housing this spring, and it has only spun about 1/8 turn since that incident.
Is this at all 'normal'? I suspect the hub bushing needs to be replaced - is that something that could be attempted with the boat in the water on a lift? I don't have a trailer - the boat is parked on a lift.
