Jack Daniels
- Joined
- Sep 21, 2007
- 266
I have a 83 85 HPchrysler FORCE and i was curious about the pitch of my prop. Stamped on the side is a 526-21, does this make sense or and i mis reading it.
Also if this is true, does that make the prop a 21 pitch. That type seems kind of high for a 85 HP, plus when you add that I am running at 6000 rpm at wot it doesnt make sense.
One more thing, if this is a 21 pitch then would it be safe to assume that the tach is incorrect or the rectifier needs replaced. WIth that high of a pitch common sense would dictate that my RPM would be lower. Thanks for the help.
