Re: Prop interchange ??
Yes, if it's has the old style rubber hub you will have to shorten the splines in the prop. No big deal, most any prop shop can do it easily enough. Lots of folks do it themselves.
If it's a newer prop with a square bore then all you need is a hub kit for the E-rude.
