On my 115 Johnson prop...I noticed before splashing my boat this year that there was a small ammount of black oil/grease/whatever coming from behind the prop. Not the end where the nut and safety pin are. Then I noticed the prop its self was loose. I tightened the prop/ then I noticed the black exhaust looked like what was leaking...anyway no problems when using the engine in forward gear, but when I use reverse the prop became loose again. Did I not tighten it enough?
