rothfm
Ensign
- Joined
- Sep 26, 2006
- 915
Bit of a long read, trying to include as much facts as I can.....I have been researching
I dont know enough about diff prop makes/models, so I thought After researchinging these forums, i would toss out some info, see your thoughts.
I have a Neptune/OMC 202 with 1993 140 looper 25". Thats a smallish 20 walk-around cuddy.
I run In MA Saltwater bays and offshore exclusively. I run 90lb Smart tabs.
Dont know hull weight, possibly 2200, plus motor, 70gals, lots of gear, ice (dam I need a higger boat!) I carry alot
I use an OMC 15.5 X15 Alum prop. I run at top end of WOT Rpm range which is 5500-6000, in fact I can get to 6100-6200 (but dont run that hard)
Overall good holeshot, decent acceleration, however, it takes alot of rpm to maintain a decent cruise, like 5000. If i drop to 3500-4000 It may start to slowely dropp off Plane. At Wot I see only 28-29 mph or so(guage and gps)
I now realize my tabs are at thier "strongest" adjustment setting as They spray way to much water all over the place. Going to test different adjustment holes, and lift them totally up temporarily.
Oh, i have the motor on the higher mount holes and also trim up. The leg is s not too low.
From reading, seems im under-propped. I feel a 19p would be a dog for me. Was thinking a 14 7/8 or 14.5 in a 17pitch Stainless(reduced flex) might be a good fit. Seems I can afford to drop a bit of rpm and be in-range without Lugging.
I just not sure about the characteristics of diff manufactures/modle and what they can do in this size....like Lift, low-end vs hi-end performance etc
My main goal is mid-range cruise performance& economy, as well as a slow troll. Very seldom can I run upper ranges due to conditions
Curious what the knowlegable folks here think?
