komatsu200
- Joined
- Jun 12, 2011
- 3
I just purchased a 1988 Blazer Drifter X-17 (17') boat with a 1982 90hp Evinrude. The plate on the motor says (operating range 4500 to 5500 rpm). Using the power tilt and trim I can get the boat to plane out nicely but no matter what I try I can't get over 3000 rpm. The prop that is on it is a (13-1/4 x 17) and is in pretty rough shape so I'm planning to replace it. After reading a few of the post on here I think the motor height may be a little high too. I've taken a straight edge and placed it along the bottom of the boat and measured from it to what I think is the ventilation plate. The plate is 3" above the straight edge. Would lowering the motor help me get above 3000 rpm? Would I need to go with a different pitch prop? Or should I try a combination of both? And if so which should I try first?
