studlymandingo
- Joined
- Mar 22, 2006
- 2,716
Okay, I've been following several of these threads, and I think I need some help here. I have an 18' Center Console with a 1986 Mariner 150, and a 60 gal fuel tank. I recently installed a 14.25 X 21 Rapture SS prop. After reading some on these threads, today I removed the vent plugs and put her in the water for a test run. Previously, the holeshot was less than desirable, and the WOT was a meager 5200 RPM. Today, the holeshot was improved some, and top-end was 5400 RPM. I'm not sure exactly what the WOT difference was other than temperature, it was a good 20 degrees cooler today than 2 days ago on the last run, oh and a can of Sea Foam in the tank. <br /><br />Now, for the motor position part; after reading all of the posts regarding raising up the outboard, I am thinking the motor may be positioned too low. Today while at WOT, I noticed the AV plate was not out of the water. The motor is on the top hole, which means it can be raised significantly. I am going to attempt a photo post here that shows the lower unit relative to the bottom of the boat.
