PROP NUT QUESTION
VADER8674
WHEN SHOULD THE NUT BEGIN TO TIGHTEN AS YOU INSTALL THE PROP NUT ON 1985 70 HP RUDE 3 CYL <br />ARE THESE NUTS TAPERED MINE IS REQUIRE A LOT OF TORQUE RIGHT FROM THE TIP OF THE SHAFT IS THIS NORMAL
Walker
Re: PROP NUT QUESTION
Unless someone put a self locking nut on there you should be able to run it on and off with your fingers.
VADER8674
looked at in the day lihgt starter thread on shaft was broe filed it down smooth replaced the nut again and she worked kust fine but thanks for the onfo it is appreciated
