Prop Nut Torque for Nissan 18hp
brnschoneck
Re: Prop Nut Torque for Nissan 18hp
What is the torque needed on the prop nut of a 18hp Nissan Model NS18E2?
im not sure however i just tighten them good n tight and push your saftey keys down its not gonna go anywhere ...
steelespike
On that little motor 30 ft lbs. should do it .
It just has to hold the prop on and as mentioned with the lock tabs down the nuts not going anywhere.
As time goes by you should keep an eye on it to be sure all is well.
Anually you should remove the prop and be sure the spline has lube on it to resist corrosion.Very important in salt
I/Os and 4 strokes.
Sea Rider
Just seat prop nut fingers tight, with point pliers or wrench go to next nut's groove/cut so split pin inserts through prop shaft's hole, once done, bend to sideways..
In salt water uses, grease entire prop shaft and splines with appropriate grease , if not, with time salt formations will seize prop to shaft and make it's next removal a bummer.
Happy Boating
