Re: Prop pitch help!?!
I think your tach is wrong. By almost everyone on here, they say that the 3.0 screams when at 4000 rpm and it should sound like your motor is gonna blow at 5k. I had the 3.0 until 2-weeks ago on a 17.5 Marada shallow v-hull, and at 4k I was clipping and the motor was pretty noisy. I would check your rpm's with an external tach, and do as mentioned above, check your speed with a GPS. Unless you have a shallow hull like the Marada, you won't get huge speed with the 3.0. Also is your boat 120, 130, 135, or 140 hp? My 19P prop with knicks in the blades got me over 40 easy with the 135hp but again that is a shallow hull.
