Re: prop pitch question
A higher degree of pitch will typically result in an increase in speed IF your engine is still able to achieve the recommended wide open throttle rpm. Each degree of pitch increase typically results in 150 - 200 drop in WOT RPM. If you are unable to maintain proper WOT, you'll be putting undue strain on the engine. 4 blade props of the same pitch will typically result in a slight decrease in top speed, but provide a better hole shot.
