Re: Prop pitch range on Force 125
Doesn't really matter. In the early one piece lowers the gear paks are interchangeable. However, when changing gear paks, you need to shim the lower so yes, it is a little faster to swap lower units.
AND, you can check the ratio by turning the flywheel two times in forward gear with the prop hard against the dogs. If the prop turns once it is 2 to 1. If it turns 1 and 1/4 or so, it is 1.76 to 1. Early units did not use any other ratios.
BTW: If you have a good running 125 DEFINITELY put it on the GT 150 with a 2 to 1 lower and a 21 pitch stainless prop. You are gaining about 45 HP and only about 30 pounds. You would expect up around 60 MPH.
