Re: Prop Pitch vs. Diameter
The pitch is the number of inches the propeller would move forward in 1 revolution, ignoring slip. As the pitch increases the load on the engine will also increase, as it would have to do more work in the same time. The spec on the 350s is about 4400-4800 rpm at Wide Open Throttle (WOT). The usual is about 400 revs change for each 2" pitch change. So, to go from 15" to 21" will knock about 1200 rpm off the top end, probably more as the engine won't be able to make full horsepower. You must also realise that the extra load imposed on the engine is right across the rev range, not just at WOT. That sort of load will most definitely kill your engine. Look out for holes blown in the pistons, valves burnt, head gaskets blown just as a start. That's even if you never excessed half throttle!
Don't do it!!!
Chris................
