Re: prop pitch
With the prop that is already on you boat run it up to full throttle and note the rpm's. Compare your WOT rpm's with the manufacturers recomended WOT rpm's. If your RPM's are lower then the manufacturers, you with need a lower numbered pitch prop. If your RPM's are higher then the manufacturers, you will need a higher numbered pitch prop.
