prop pitch
Mikemcnutt
Just got a 1985 pro craft with a mercury 200. I’m not worried about speed too much. My son and I can cruise from fishing spot to fishing spot around 25 mph and be happy. The prop is a 4 blade 26 pitch. It seems like the motor is screaming and takes forever to plane out. Once it does it takes off. I think I am burning A LOT of gas just trying to get up.
should I trade props???
what pitch should I try out??
Sea Rider
What's the min-max wot rpm factory stated for that motor ? Any motor should run at least to middle rpm range as loaded, although running towards max wot rpm is much preferred. Is the current prop being used a 1985 one ? if so, check if with a spun prop already, does the combo counts with a tach, without one and wot revs achieved won't see the light at the end of the tunnel anytime soon for propping the motor right for your application.
Happy Boating
dingbat
A 26 pitch prop should not be “screaming” on a 200 hp motor.
What is your definition of screaming? How many rpm? Two strokes run at a lot higher rpm than a 4 stroke.
You mention that you just got the boat. Are you a seasoned operator or new to boating?
Proper trim and throttle manipulation are key to getting out ohf the hole in a timely fashion.
Texasmark
Without reading other replies, my knee jerk reaction is that you have a SS ported prop and the holes are too large, or the engine is sitting too high on the transom for the way you drive, or you are coming up with the trim too far out and if that would be the case tossing a good rooster tail till up and gone. I didn't add a spun propeller hub as you said once it locks up you are gone. Spun hub would not do that.
Ports allow exhaust gasses across the blades which reduce the density of the water allowing engine HP to develop rapidly and in doing so make for a quicker hole shot with less load on the engine at that time. Then once up, water velocity running past the ports seal off the ports and the exhaust is out the end of the barrel where designed. If you are running with the ports sealed and you slow down to the point where the oncoming water pressure isn't sufficient to seal the ports, the bypass function will reintroduce itself and you will return to high rpms and slow forward speed.
Engine sitting too high would contribute to ventilation; prop sucking in ambient air which accomplishes the same thing as ports and if you have both ports and excessive height, you can really experience what you said you have.
Trim out too far allows the engine to once again suck in ambient air and is associated with initial porpoising (bow oscillating up and down) as the hull exits the water. As speed increases, which on a light hull with a 200 hp mil, could happen in seconds, the porpoising amplitude and frequency are reduced until the speed catches up to the trim angle and the boat takes off....all in a matter of seconds.
My 2c
Sea Rider
How would you know at which wot rpm the motor is screamming if without a tach. Ear tach is no bueno, not even having a musician ear...get a tach and tach right that motor at wot as loaded to start with and cut the theoretical speculation going on..
Those Merc motor runs well on any of the 4 motor heights reommended by the manufacturer which are being repetively posted here, visually check if running inside any of those mentioned height parameters. Adjust as needed for you application and preference and TACH the motor..
Happy Boating
QBhoy
I’m going to second the idea of the vent plugs being missing out the prop.
say this because usually the engine screaming and taking ages to plane on a boat set up like that, doesn’t usually go hand in hand.
Also probably likely that a 26” prop is unlikely to let that engine be in much danger of over revving.
23/25” 3 blades like the trusty old laser 2 would be the usual favourite for set ups like this usually. Or they used to be anyway.
Likely more common would be tempest and fury props these days. But almost sure a 26 would be on the high end of the suitable range of props for sure.
check you don’t have a prop with fully open or missing vent plugs.
