I have a 2011 Evinrude E-Tec 130 (that I absolutely love!) on an 18' Winner Center Console (with a full transom). It's a long story but I had to repower the boat in 2010 when the original engine bracket failed. The boat will move at about 33-35 MPH at WOT (about 5200 RPM) and likes to cruise at 22-24MPH (measured via GPS) at about 3200 RPM.
1st issue - I have the original aluminum prop (sorry, don't know the pitch or diameter) and it shows the normal wear and tear of an new/inexperienced boater. The paint is worn from the outside edge of all 3 blades (as well as the engine skeg), funny how sand and bottom do that! There are a few nicks & dings on the edges but nothing major. However, the front (bow facing side) of each blade has scarring and pitting at the point where the blade joins the hub. I believe this condition is due to cavitation and the resulting 'boiling water' and air bubbles 'burning' the aluminum.
Question 1 - Will a different prop (not stainless vs. aluminum) with a different pitch (or even diameter) resolve/reduce the cavitation and pitting issue? I realize that some of the bubbles may be the result of hull imperfections or height/positioning of the prop and the resulting stream of air bubbles that hit the blade and get compressed into the space near the hub,
2nd issue - My boat 'likes' to travel at speeds of 0-10 MPH and 20+ MPH. I can get up on plane in about 6-8 seconds and can maintain plane at about 20 MPH and 3100-3200 MPH. All well and good until there is a bit of a chop. As a result of the new bracket and engine the boat is very stern heavy. Even with the engine trimmed as are as possible, (tucked in as I like to describe it) the boat bounces pretty good in a 2+ foot sea. I know hull design and total weight are key factors in this equation but I do not like 'slamming' into the troughs at 20MPH. If I back off the throttle even a little I lose RPMs until I'm close to 2000 and the boat is moving at 10 - 12 MPH with the bow way up.
Question 2 - Can a different prop change the speed at which the boat can get on, and stay on plane? I'd certainly be willing to sacrifice some top end speed to be able to plane at 15-18MPH.
Thanks for any and all help
