harleymike
- Joined
- Jun 19, 2008
- 32
Hello
I hope you can help. I have a 97 starcraft superfisherman,with 70hp force motor.
Problem is this. With 4 adults in the boat it will not come up on plane. It just plows water.
If I put one person on the bow , it comes up on plane. Is this normal, or is there something I can do to
improve this.
I have a 14pitch prop. I purchased an 11 pitch prop, but have not had the opportunity too try with 4 adults. I have noticed with just two adults and 3 children, both props work fine, but the 11 pitch seems too rev too high, and not as much top speed.
I also put dolphins on the motor.
One thing I noticed about the two props, The 11 pitch ;and 14 pitch both the same size , but the 14 pitch has differant shaped blades. The 11 pitch has skinner blades, the 14 are more like big elephant ears ( more surface area) is this maybe a problem.
Any suggestions would be great.
I prefer the 14 pitch, but is it a design issue with 4 adults in the boat.
thanks mike
improve this.
thanks mike
