Hi,
Once again looking for sage advice. I spun the hub on my prop and I decided to replace it with new. The problem is, I can't figure the size from the numbers stamped into it, "176884". I've just spent the last few hours digging through the faq's and forum for prop advice and think I have a decent handle on where to go but still have some questions. The Michigan Wheel prop-finder for my 1990 120hp v4 spits out three different props. 13 1/4x17, 13 3/8x17 and 13 3/4x15. The best I can figure my current one is to be 13 3/8 and I'm guessing 17 because of the number stamped on it. If I measure out the 13 3/4 from the shaft if leaves me with @1/4" clearance to the ventilation plate. Is this too close? My boat is a rebuilt 1978 Wellcraft 20' CC that's pretty heavy. The current prop moves it along pretty well, but the WOT is only @ 5200-5300. Will the extra size negate any benefit from the smaller pitch?
I'm open to any advice on brands/materials/size etc. The boat also seems to be guzzling fuel (not that I expect it to be miserly...) I'd gladly sacrifice some speed for better fuel comsumption, if a different prop can help that. One thing I did realize through my digging today, was that my motor is sitting too low. The ventilation plate is @ 1 1/4" below the keel. I'm gonna raise that tomorrow.
Thanks for any help!
Evan
Evan
