I have a 1970 evinrude 25hp. model 25002C, the prop is in great shape, but the [bushing?] in the back of it where the shear pin rests is worn. Whenever I put it in gear it shears off the shear pin. Im assumning its due to the "slop" in the fitment. Is the bushing pressed into the prop? I cant find a part number for it, I can only find a # for the whole prop.. Also in doing a little research I found 2 different part #'s for the prop? a 9 x 9 and a 9x10. what does this refer to, and how do i know which one I may need? Thank You in advance.
