Prop question 1990 Sea Ray 220cc/ 260hp A1
MFG197
My friend at work has this boat, he is currently runnin a 15x17" prop and says he hits 35-40 MAX speed. I have a 1996 215 Express Cruiser with 250 hp merc and hit 50. <br /><br />Should he be going faster, I am not sure what RPM he hits, what is the max WOT rpm for his motor?<br /><br />His prop is slightly damaged and is considering buying a new one should he stick with the same pitch/diamter or play with it?
walleyehed
Re: Prop question 1990 Sea Ray 220cc/ 260hp A1
Boat design, including I/O vs. Outboard has alot to do with speed due to weight issues of an inboard. Also, they can't raise the engine height and gear ratios are different.<br />I bet you are running somewhere near a 20 pitch prop on yours...19 maybe???
cuzner
Depends on the rpm at wot.Whats he do with his boat? ski ?. With that rig, and engine sounds like an 19 pitch would be a better match. Don't think itt'le get him up to 50 though.If he moves up in pitch he will lose some hole shot though.<br /><br /> Jim
