Prop Question for 1977 20hp
Ginder75
I am looking at new props for a 1977 20hp serial number 4580916. I have found several suppliers but they carry similar sizes.<br /><br />My question is this: I am finding either 2 blade props in an Eleven Pitch, or Three Blade Props in a Nine Pitch. Not to mention the various materials they can be made from.<br /><br />This motor is on a 15' Duracraft fishing boat that may top the scales at 1000 pounds fully loaded, gear and all. I have a 2 blade prop in Eleven currently, but I was looking for a back up and a little more speed if possible. I do not have a tach, but the engine does not seem to bog down at full throttle with this load. It is slow to plane, but then all is fine.<br /><br />If anyone can help me make sense of the 2 verses 3 blade configurations I would greatly appreciate it. And feel free to offer your opinions on the different prop materials out there.<br /><br />Great Website and Great Information<br /><br />Thanks,<br />Ginder75
Motor Boater Bill
Re: Prop Question for 1977 20hp
According to the Seloc manual, which is the only direct reference I have found on this, the two blade 11 pitch should give more speed than the three blade 9 pitch, which is recommended for heavier boats and heavier loads, such as water skiing. They include some caution about the potential to over-rev with the three blade prop if lightly loaded. I have a three-blade on my boat and took it for its first full scale test on the river, and I think I need to switch to the two-blade. It seems to need a bit more traction at wide open throttle.
Ginder75
The other comment I have heard on the two blade verse three blade was that the three blade provided smoother operation. My motor acts like a ticking time bomb at idle, but at full throttle it purrs like a kitten. I have been through the electrical system, I have worked on the Carb, and adjusted this motor as well as I can adjust it. My only complaint about the motor is its idle. I know I can not compare it to any of the newer models on the water, but I feel it should preform better than it does.<br /><br />I am running down rumors now!<br /><br />Thanks for information.<br /><br />Any one else want to take a stab at this one?
ShafferNY
This is interesting. <br /><br />I was given a 1978, 20hp merc that has the three blade prop on it and given an extra two blade prop.<br /><br />I just automatically assumed that the three blade prop probably pushed the boat better, so that's why it was on there verses the two blade.<br /><br />I haven't put it on my boat yet, but now I'm curious.
Ginder75
I keep asking and still no solid answers. Some say the two blade is a racing prop, and the three blade is a work horse. I am happy with the performance of my 2 blade in 11 pitch, but thought a 3 blade maybe better since all newer motors have three blade props.<br /><br />My real question was is this - Is a nine pitch 2 blade the same as a 9 pitch 3 blade? Will they preform similar? What can be expected from a three blade over a two blade?
Dhadley
Thats an excelelnt question. And very hard to answer. Heres why -- to compare any two props, any two, they have to be the same material, brand and style. Any variance and youre no longer comparing apples to apples.<br /><br />Some props of the same pitch will run a higher X dimension than others. Some have bow lift, some stern lift. Some have overall lift. <br /><br />I would expect that a good 3 blade prop will work better overall than a 2 blade. It has to do with blade area. <br /><br />To properly set up a rig, a tach is critical. However it can be done. Lets try something. Look at your 3 blade prop and count the splines. Also, what diameter is it?
Ginder75
I know that is part of the problem. Any deviation and it is a different test. Heck you can have two props from the same manufacture in the same style, size, and pitch and they will act a little differently.<br /><br />I have a 9 7/8 dia, 2 blade prop in 11 pitch. I do not know the number of splines offhand, but I can either look it up or post tomorrow.
Motor Boater Bill
Pitch describes the distance a propeller would move forward in one revolution, assuming a theoretical "no slip" situation. So, regardless of the number of blades, in theory an 11 pitch prop will go faster than a 9 pitch at the same RPM's. In practice, a three blade prop may slip less than a two blade, at least during accelleration. <br /><br />Ultimately, it is about matching the boat, motor and prop so that you don't lug the motor and don't overrev. Most of the experts on this board will say you really need a tach to fine tune this. There won't be one right prop for that motor, but there may be a best choice for that motor on your boat, with whatever load and use you normally have.
Motor Boater Bill
Acording to the prop chart in the Mercury factory service manual (C-90-74041), the 48-3348A1 prop is an 11 inch pitch, two blade, and for boats up to 1000 pounds will run 22-33 mph at maximum RPM. <br /><br />The chart also shows a prop #48-33482A1, two blade (I wonder if this is a typo and it is really a three blade?) with a 9" pitch, for boats weighing 850-1600 pounds, making 13-24 mph at maximum rpm.<br /><br />If anybody has one of those 48-33482A1 props, let us know if it is two or three blades. My three blade nine inch pitch is a Michigan Wheel, and it is supposed to be the replacement for the Merc 48-33482A1.
