I've had this motor for about 5-6 years now, it's a 2001 Johnson 55hp 2cyl commercial outboard, with an odd 23" shaft. Outboard is/was manual everything. I've since converted it to power everything, including a CMC PT130, and when that was mounted I used it to raise the outboard the 3" I needed, since my transom is a 20" transom. I've had a stainless prop on it since I got it. It's made my Michigan Wheel, Rapture model, and is 13 1/4x17p. I have no guages to go with this outboard,so I can't give my top RPM since I don't know. The boat is a 16' Tracker Grizzly aluminum boat, so not much weight to it really. Top speed as recorded by GPS with a normal load (which is 6g of fuel, myself, and my gear), is 33mph. It seems to take forever to get up on plane if I have just 2 people in the boat, so an additional 130lbs (it was woman). Before I purchased this outboard, I had a 1978 35hp Johnson on it with one of their factory SS props and it would do right at 30mph, so would think a 55hp newer style would gain more than 3mph, and the hole shot is worse.
Any help would be appreciated, including if you want any more info,I will see what I can do.
Thanks You
Thanks You
