Theoutdoorsman
- Joined
- Mar 6, 2003
- 669
I'm currently turning a 13 1/4 X 17 pitch alluminum prop with my '71 Mercury Inline Six Cylinder. The boat will run about 40 mph with a full load and I'm getting a really good hole shot (about 1 boats length to plane). Although I only run the motor at 5,000 RPM's for better fuel ecconomy, I suspect my maximum RPM range is a little high at 5600-5700. And, I can't go any bigger in pitch size. I am considering purchasing a steel wheel but I'm not sure if the advantages I might get will warrant the cost of the switch. Any thoughts as to what I could expect by making the change to steel? I suspect my RPM's will drop a bit, but I can probably stand to loose 200 or so anyway. Bare in mind, I'm currenty getting a good hole shot as well as acceptable top-end speed. In your honest opinion, will the switch be worth the cost? And what should I expect to gain? Thanks........Alan
