Prop question
Is the prop supposed to move on the hub at all ?? I have a 125 hp force motor. Just out of curiosity ,<br />I scribed a line on the hub and the prop casting to check and see if it moves at all. Took the boat out with 5 adults in its.<br />I hit the throttle, and it takes off pretty quick considering the load. Planes up pretty easy.When I got it out of the water,checked the prop and<br />discovered the prop had turned on the hub somewhat.I didnt seem like it was slipping is this normal??.If it is slipping, does that mean if I got it rehubed,<br />it would work even better??<br />Thanks
blueboat1
Re: Prop question
I wouldnt think so. I an not 100% sure but as a kid i remimber my dad tossing a prop for that reason. Somebody who know for sure will chime in and we'll both know!!!<br />scott
roscoe
Re: Prop question
Sounds like the hub is starting to wear out. It should not spin if in good condition.
sharkcat
Re: Prop question
I have been told by a prop guru that all hubs will creep a little what you have to watch out for is excess slippage that is not cavitation/ventilation.If the boat is accelerating well etc dont worry its normal :cool:
