Ok guys<br />I have a 89 Bayliner 19 foot Capri open bow. it had a 5 liter v8 and OMC outdrive. I jsut had the motor replaced and it runs great. The only thing is the boat only revs to 36-3700 RPM. but it was sort of rough out that day. It has great pick up off the bottom. Now I looked and i saw the last owner had a 4 blade prob and there is a 3 blade prop in a storage bin. The 3 blade prop looks like it got dragged up a launch ramp or hit something so its unuseable. <br />Now I had jet skis and When you switched to a different prop you could loose as much as 500RPM from the top. Anyway I know a a bunch about jet ski props and wont bore you. Im thinking I should go back to my stock 3 blade prop. I dotn plan on towing skiers and If I do the prop is a snap to change. What is the stock prop for that bayliner?<br /><br />Thanx<br />Rob
