prop question
pappy3
hello I have a prop pitch question ! I have a 1986 16 FT STARCRAFT with a 1992 johnson 88 special turning a 13.25x 19 pitch prop . I run at wot 38 mph with 4 people or 38 mph by myself
pappy3
Re: prop question
I don't have a tach, so I can't tell you my rpm's ! Thanks for any help you can give!!
jimmbo
Re: prop question
If your speedo is accurate, your prop is too large. A 17 would be a better choice.
38mph with a 19 prop will give about 4600 - 4700 rpm, which is low
BTW what is your quastion?
pappy3
Re: prop question
my speed is correct on my gps and my speedo! i DON'T THINK GOING DOW IS WHAT i NEED SIMPLY BECAUSE MY TOP SPEED WITH A HEAVY LOAD IS THE SAME WITH JUST ME! not HOLLERN JUST didn't look up to see I had left the caps on:D Thanks
tommays
Re: prop question
Youn need good info
Real speed
Real RPM
Tommays
pappy3
Re: prop question
real speed GPS 38 REAL SPEED ;SPEEDOMETER 38
RPMS ??
pappy3
Re: prop question
i KNOW i NEED A TACH ,i JUST HAVEN'T FOUND A SECOND HAND ONE YET! i MAY HAVE TO GET A NEW ONE:D Again not hollern just didn't look at my screen! SORRY:eek:
pappy3
Re: prop question
Please don't think wrong of me I don't know which way to go, but all I can do is relate to you what I know on my end! I don't have a tach , my boat is 16ft, I have a hardly used 90hp motor that is about 3 inches above the keel and I can go the same speed with or without 4-5 people in the boat in about the same time! No lugging with a load or without ! Thanks for responding to my questions !
pappy3:D
72SideWinderSS
Re: prop question
pappy3,
Try this:
"http://www.tinytach.com/tinytach/gasoline.php"
pappy3
Re: prop question
thank you so much I really can use that! johnny
