prop question
88malibuskier
re-built an 88 malibu skier...........origanally had a 260hp merc..............new motor is approx. 510hp................how would i prop this to take advantage of the extra hp? stock prop is 13x13 1" shaft
oldjeep
Re: prop question
Depends on what you are trying to do. If you are using it for skiing I would just leave it the way it is. If you are trying to set speed records then maybe swap it out.
