Re: Prop Question
We still need you to get us the wot rpm and speed by gps.And remind us of the prop size.
Speed is easy with a gps. Some cells have a gps app.
No change in rpm I would suspect the tach.
Rpm alone doesn't mean much. It only indicates the rpm.If we have the prop and speed we
can usually figure out if there is a tach or motor problem.
For instance your at 4200 rpm and need to make up 1200. That would require up to a 6" reduction in pitch.
That would put the prop at about 11" The size you would use on a very hard to push pontoon.
With your rpm and speed we can see if its a motor problem or else where.
1)
Performance issue you are trying to correct.
Boat is slow
2)
Current prop manufacturer, model, aluminum or stainless as a minimum.
First prop: don?t know manufacturer, don?t know the model #, aluminum.
Second prop: QL, A3r, aluminum.
3)
Current prop diameter and pitch.
First prop: 11-3/4 x 17
Second prop: 12.5 X 13
4)
Wide open throttle RPM and speed with an average load.
First prop: 4100 to 4200 at 11 mph (gps)
Second prop: 4100 to 4200 at 12 mph (gps)
5)
Engine/drive make, model, year, and HP
Johnson, J50TLEOD, 1995, 50HP
6)
Boat make model, year, length and weight
Ebbtide 166 STE, 1987, 16.5?, 2240 lbs. including trailer
2 carb rebuild kits w/ floats on the way from iboats.
