prop question
ob
anyone know whether a 13x19 prop would operate my motor within it's recommended rpm range? I presently run a 13 3/8x17 omc sst on a 15ft. boston whaler dauntless.local shop has omc 13x19 used in good shape for 165.oo , but doesn't want to let anyone check it out before buying.Motor will turn around 6200 rpm with light load with the 13 3/8 x 17 prop.on a 1995 70 hp evinrude.any feedback is appreciated.
JB
Re: prop question
Howdy, OB.<br /><br />You are underpropped now. 6200rpm is too fast for OMC triples.<br /><br />I think your idea of going to a 19" is a good one. That should allow you WOT of around 5500rpm to 5800rpm.<br /><br />Good luck. :)
ob
Re: prop question
JB is it still ok to use the 17 in. prop for skiing or full occupant load since changing props is realtively easy?
steelespike
Re: prop question
JB is right your motor will be happier and last longer.<br /> Just be aware your hole shot will be slower<br /> getting a skier up will take a little longer.<br /> Top end should be faster.
Dhadley
Re: prop question
Why not use the 17 for skiing or tubing or a spare? Ber careful buying a used prop. If its been reworked it may (or may not) do strange things. I can see him wanting you to pay for it but he should offer you a "money back" deal if, after a tryout, it does not work properly on your rig. Of course that means you return it in the same condition you took it in. <br /><br />Good luck!
ob
Re: prop question
thanks for the feedback . I think I'm gonna go for it. I'll definately ask if he'll allow me a refund if it does'nt suit my motor
