I have a '73 Mercury 850, 85 hp. Currently it has a 21 pitch prop.<br /><br />I've read a lot of posts about WOT rpms and choosing your prop at least partially based on this. If however you don't plan on running around at WOT and you're satisfied with your holeshot does it really matter what prop you have, within reason, if you plan on running at 3500-4000 rpm?<br /><br />Also, I have small pits, about 3/16ths diameter on the forward side of my prop down where the blade attaches to the hub. What would cause this?<br /><br />Thanks
