Prop Questions
txtoyman
I have a 14 1/2 X 15, 3 blade SS on my Honda 150 - perfect, tops out ~5800 RPM. I want to put either an aluminum or composit on for this summer, then use it as a backup. I'm headed for some rocky ground and the softer will be easier repair.
But what size do I use - for example I don't find the same prop in Aluminum, larger and more pitch are available.
How about the Piranha props - replacement blades sound good to me, but what size ?
usskydvr
Re: Prop Questions
When replacing a SS with alum unit at that low pitch you generally go up in diameter so I would go up to a 15" or so.
