prop remove to replace seal kit mercury 402 40hp
Cjames2118
Hi I'm trying to remove the prop shaft and I can get it out I've tryed submerged in diesel fuel for 2 weeks and and I've heated it up with blow torch and even broken at sliding hammer trying to remove it any got any other information about removing the prop.
Attachments​
Make up a spacer / tube / wood stack and use the prop nut to pull it and get it moving.-----Corrosion products have jammed it up.
