Prop replacement - lube on thrust washer?
convergent
I am replacing my prop and there is a brass thrust washer that I assume I need to leave on with the new prop that didn't come with one. It is tapered on the shaft. I got a tube of grease to lube the shaft. I am assuming that I should not let any grease get on the face of the washer, correct?
Barnacle_Bill
Re: Prop replacement - lube on thrust washer?
It won't hurt it to get grease on it. I like to use anti-seize when putting a prop back on.
convergent
But is it supposed to be greased? I covered the shaft splines really well but left the washer dry and clean. Should that be ok?
Bob_VT
As long as the shaft is greased you will be okay....... the washer will end up with grease on it when you run the boat
