I have a prolem with propping a 15 footer. The boat is some 1200 pounds with twin mercury 500's on a stern bracket. If propeller selector says that for 16 foot, and some 1600-2000 pounds of gross weight single mercury 500 would require propeller 12" x 11", does that rule of thumb changes with twinson the stern, and should I use higher pitch, or a bigger diameter propellers. By the way, since one of these 500's is on a repair, i am using the boat with one, and with 11 1/2" x 13" propeller, and it, for lack of better words 2sucks". can't get it in a plane with more than 3 people onboard, and the rpm (by the sound of it) are lower that usualy (with 12" x 11" propeller). Thank You in advance, Niksa.
