rhillman75
- Joined
- Jul 28, 2010
- 176
So I have "combed" the internet to find out what prop was "intended" for my 1996 Sylvan V196 with a Mercruiser 4.3LX and a Alpha One Generation 2 outdrive with I believe is the 1.81 gear ratio. I simply cannot find anything! It had a 4 blade, 19P, 14.75" diameter last year that my wifey "smoked" in shallow waters. I had a back up which was a 3 blade, 19P, 14.75" diameter that I used, then I noticed one blade had a "through" crack (couldn't be repaired), that went to the scrap yard. Now I am left with the dilemma... "what the ???? do I use now? I know with the 4 blade, 19P, 14.75" diameter I was close to WOT rpms, operating at about 35 pmh, but if I wanted the most MPH (regardless of mpg), but within "safe" operating rpm range, where do you start? I have no marinas in the aea that offer the "try it before you buy it" oncept, so now I have a drive without a prop. Almost all of the "internet" prop selectors steer you towards a "lower" and sometimes a "higher" pitch prop at different blades and different diameters. Is there anyone that has the same setup as mine below? And if so, what is your starting point?
