I'm not quite sure how I should go in getting a different prop.Right now I have a 12.25x15 prop on a 1991 alumacraft Dominator(16 ft.) with a 1991 40hp Evinrude.My hole shot is okay and my top end is 28-29 mph(gps).The problem I'm having is low RPM's, at WOT and trimmed out ,I'm only turning 4600.The motor is rated at 4500-5500 RPM's.I've done a compression test on the motor and both cyl.are at 110,so I know the motor is good.I've also raised the motor so the cavatation plate is ever so slightly above the bottom of the hull.Should I go to a 12x13 prop to get more RPMs and hopefully better performance out of the motor? :/
