pvmtsux
- Joined
- Oct 27, 2008
- 90
I recently bought a 1998 Regal Destiny 200. It came with a 3 blade alumminum prop 14.25 with 21' pitch and a 4.3L Merricruiser I/O. I noticed that when I ran the boat the RPMs were very high, about 6000 WOT. I also noticed on my last outing that there was an unusualy grinding sound coming from the sterndrive. After further investigation I found that the prop had about 1" of play in it (up and down) the spline teeth were exposed and the nut is all the way down. My question is: 1. is this the correct prop for my boat? 2. Which direction in pich chang do I need to go to bring down the RMP's (higher or lower in inches)? 3. Why is there so much play in prop? 4. What prop (dia. and pitch) would you recomend using as I am in the market for a new one?
