Re: Prop selection
UU, Thanks for the info. Are you positive on the gear ratio? If mine is 2.25:1 then this is better for larger pitch.(I can check it this weekend to double check)<br /><br />I have looked over the 3 props I have and none of them have any stampings that I can see except for the number on the hub.<br /><br />Even if I did have the pitch for the prop I have, I would not be able to make an accurate decision based on RPM because I have not wanted to go past 6200 RPM.(not sure really how many more rpm's I can get, just know it's more than 6200 now.)<br /><br />What discourages me is that when you look at prop manufacturers for a 135hp motor they give a max pitch prop available up to 21" pitch. The 22" and above are for the 150+hp 15 spline motors.(not that they don't make them, but the popularity of higher than 21 is not there)<br /><br />@23" pitch, 10% slip, 5900 rpm is giving 52+mph. that is plenty fast.<br /><br />I guess what I was looking for was someone who has tried these combinations already and could give advice on how that prop seemed to work or others in that same prop range.<br /><br />I just bought a 389514 23" 12 3/4 SST-2 prop. If it doesn't work, I will have to lose some weight, lol...I may have to re-pitch it, if it's worth it or just sell it. It also makes it difficult in choosing a prop due to different cupping, raking, blade tip design, etc.<br /><br />I don't see alot of people using the multi-pitch props or talking about them(the mercury ones, not the composite flex ones). sounds neat to have a 13 pitch prop for takeoff and move it's way up to 23!
