Re: prop selection
There are so many variables and you don't give enough information: We know it is a 1987 Force 85 Hp engine, but that's all.
We really need to know at least the size boat, size of prop on the engine now, current RPM, and current top speed.
The only thing I can say right now is that if you are using an aluminum prop and switch to the same brand and size stainless, then you will experience about 400 RPM more and about 2 MPH higher top speed.
As far as brands, Michigan makes props that will fit the Force. If you look right here on iboats stores you will find Force props. Many Mercury props will also fit if the hub diameter is 4 inch (small gearcase). You do have the option of using open hub props (through the hub exhaust) or closed hub props.
The first four photos show open hub props, Ballistic stainless, Vortex aluminum, Michigan stainless with tailcone installed and again Ballistic. The last one shows the difference between a Chrysler closed hub stainless (bottom)and a Michigan open hub stainless (top)
