hawgslayer75
- Joined
- Feb 14, 2012
- 5
Hey guys been a while since I've been on here i have a 1971 650 with a lower unit off an 1150 i could only get 8 mph out of it no matter what i did, i did some research and found out the 650 has a gear ratio of 2.3:1 & the 1150 has a gear ratio of 1.7:1 the prop i was using from the 650 was a 12 3/4 x 21 pitch only got 8 mph off it the motor is on a 1972 15' browning tri hull the prop that came off the 1150 was a 13 x 17 the best i could tell by the michigan part # i got about 26 mph with that with 2 guys in the boat i was wondering what prop i should use to get a little more speed out of it mabye 35 mph thanks
