Re: Prop shaft moves in and out is this normal?
Hey smokin..Mine moves around barely...maybe an 1/8th inch. But when I redid mine, I noticed that there was no way at all to adjust it. The only way it could get any looser is by wear on the gears. Likely your issue. Mines a 50 hp..So i could be wrong..but the gears in mine, the shaft gear to be exact is what holds the thing in. If it were me...I would just go ahead and waste the 20mins to drop the lower foot, and put it in gear..once done I would pull hard on the prop and see if it caught at all...if it was still smooth, then i dont think I would worry about it. If it caught...well, then I would take it apart and check, who knows..you may be able to space it somehow, but most likely you would need new gears. Hope this helps man...
