Re: Prop shaft seal...Can I do this???
I think you should pressure test it. It might not be the prop shaft seal at all. Maybe it's the driveshaft seal under the water pump (?). I made up my own pressure testing device using a small rubber stopper, some small tubing, a stopcock (medical kind), syringe and a pressure guage. I drilled a hole through the stopper, and slipped fine, stiff tubing through the hole, used silicone to seal/stick it in there. attached other end to stopcock, and attached the pressure gauge (via a pice of tubing) and the syringe also to the stopcock. Reality is you probably don't need a pressure guage. You just wanna be able to pressurize the LU a bit to see where the air leaks out.<br /><br />Take LU off, drain the oil, put stopper in drain hole, and inject air into it with syringe. Should hold 10 psi. Yours won't (air will leak somewhere). Lay LU in a kiddie pool and see where bubbles come out. On mine it was from the driveshaft/water pump. Removing the pump base, I saw the driveshaft seal had separated. Replaced pump base (& seal) and re-tested. Held pressure no problem. Reinstalled, refilled with oil, got no water in all season.<br /><br />HTH,<br /><br />Brent
